One turn signal light not blinking
Hello:
I have a '65 Mustang with a turn signal problem. When I set the turn indicator stalk to signal a right turn, the front passenger side turn signal doesn't blink, but the tail light blinks. Both turn indicators on the driver's side work fine when I signal a left turn. When I pull the head light switch half way out, both front turn indicators turn on (steady, no blinking) as expected. Thus, the problematic turn indicator light is getting power, has a good bulb, and has a good ground. What's going on here? The only thing I can think of is a faulty turn signal switch in the steering column. Does anyone have experience with something like this?
Cheers
Mike
Cheers
Mike
Hello:
When the light didn't start blinking as expected, the first thing I did was put in a new bulb. I went to the parts store, got a new pack of bulbs, and put in a new one. I can try putting the bulb from the bad light into the working light just to make sure I don't have 2 bad bulbs.
Cheers
Mike
Cheers
Mike
I had that exact same problem, for me it turned out being the turn signal switch. Got a new one from cjpony
Some advice to share when I replaced mine I tied a string to the old wires so when I pulled it through I would have something to guide it back through, rinse and repeat.
Also I was only able to do 2 wires at a time. Not much room to move in there.
Hello:
Cheers
Mike
Cheers
Mike
