65 mustang no low beam headlights
got a 65 mustang conv.can not get the low beams to work.got high beams.new dimmer switch.got power switching at the dimmer switch but not at headlights.anybody know what could be problem.
go to the main connector in the firewall and check the green/black wire and the red/black wire for voltage(same color wire on both sides of the connector). These are the Hi/low wires although i can't remember which one is which. If you have voltage on both of these wires here, then you have to continue to chase both wires to the driver side headlight.
Once you get it sorted out, I'd add headlight relays. Then they can carry the load instead of the switch. The bulbs will also receive full voltage, so they will be brighter especially if they are halogen instead of the original sealed beam.
Diode Dynamics
28
05-26-2022 12:02 PM
ShaneB26154
35
03-04-2021 04:05 AM
