Well I got my feelings hurt today...I'm switching my 65 fastback over to a v8, I found a 1964 1/2 that was a 260 car..It had the 8 inch rearend but someone had switched the car over to disc brakes...well after buying the car and tearing everything apart I have discovered that everything is identical to my I6 parts like the sway bar, upper and lower control arm and the suspension, only difference is the spindels..could it be a got a fluke car? Even the steering arms are the same size as my I6...Any info will be great guys...Sorry for any typos posting from my phone
Awesome you guys are life savers...so let me get this right I just have to change out that one linkage not the whole steering setup...Also aren't the sway bars the same as well...
That looks like a 69 linkage, which you can't use. I wouldn't use the 69 spindles, either. They'll work "OK" but not as well as correct 64-66 spindles.
Well the spindles are disc brakes, and why will the 69 linkage not work..It looks like the picture to me...I hope all of this will pan out I'm in this car for about 600 dollars..
