Bad Day
Old Dec 10, 2011 | 10:51 AM
2+2GT's Avatar
2+2GT
Well the spindles are disc brakes
The 67-73 arms (just like the Granada) are the wrong angle and length for a 64-66. They'll work, but the turning geometry will be "off".
and why will the 69 linkage not work
It's too long for a 64-66. And of course, the 67-70 pittman arm goes on a 1 1/8" sector shaft, while the 64-66 gearbox has a 1" shaft. Some early 67's had a 1" shaft, but that pittman arm is the most expensive, tipping the scale at $160.
Old Dec 10, 2011 | 11:17 AM
Dats1NiceMustang's Avatar
Dats1NiceMustang
Well after looking at several pictures of the 69 linkage it looks nothing like mine because it has a curve in it...Mine looks just like the ones I have seen on ebay for a 65/66 so I think I'm good...I have seen other people that has run the spindles just fine..So I don't see how it will throw off the "Geometry"...Do you have anymore reading on this?
Old Dec 10, 2011 | 12:00 PM
Dats1NiceMustang
Well I called Steve at MustangSteve's and he said I will be fine with the 69 Spindles, that a lot of people run that setup...He said I will have a little bit of bump steer, which I was going to go with Borgeson powersteering anyways
Old Dec 10, 2011 | 05:45 PM
2+2GT's Avatar
2+2GT
Originally Posted by Dats1NiceMustang
Well the spindles are disc brakes, and why will the 69 linkage not work..It looks like the picture to me...I hope all of this will pan out I'm in this car for about 600 dollars..
This is the 67-69 center link. It's too long, and requires pitman and idler arms that won't work right on your car.
Oh, and the 65-66 disc brakes used the same spindles as drum brakes.
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zachary1988
Sep 4, 2015 03:04 PM
Emblazoned
Sep 3, 2015 10:45 PM
cbird1177711
Sep 2, 2015 04:12 PM
