LED tailights don't work when driving??
Old Jan 8, 2012 | 10:37 AM
waldo786's Avatar
waldo786
Default LED tailights don't work when driving??
So I replaced my rear tail lights with LED boards and they work fine. Until you actually start driving. Anyone have any ideas why this might be? They just kind of flash and then go dead. My guess would be they aren't getting enough power, but I'm not sure, and if that's the case, why do they work when the car is not in motion. Did anyone here that's using LED's have to wire anything special in?
Old Jan 8, 2012 | 01:42 PM
Coupe's Avatar
Coupe
So the tail lights dont work when the headlights are on, or is it that the brake lights dont work?
I would suspect a ground, I grounded mine to the rear tail light panel/vertical trunk brace that the fuel filer passes through with a tec screw when I installed, I did not ever try to run them before a dedicated ground was used.
Old Jan 8, 2012 | 09:50 PM
waldo786's Avatar
waldo786
Thanks for responding. The lights all do come on when the headlights come on and the brake lights work when the car is in park and running, it's just when the car is actually driving that they don't seem to work. I do have a ground that comes up from the backup light and I think it's grounded on either side. Curious how you ran a dedicated ground is that the same way yours are grounded? Sounds like they are grounded in the same place at least.
Old Jan 9, 2012 | 11:53 AM
Coupe's Avatar
Coupe
Each of my lights has three wires, tail light, stop/turn, and ground. I chose to ground at the back of the car instead of sending a ground wire back to the dash area. Basically I wired them like a trailer.
djbigskrilla
Sep 20, 2022 01:04 AM
Elcameeeno
Aug 19, 2015 11:19 AM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
cema93
Aug 10, 2015 09:35 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
