Engine and transmission
Old Jan 21, 2012 | 05:32 PM
USMustangC's Avatar
USMustangC
Default Engine and transmission
I have a 1968 ford mustang 302 CID V8 and I'm looking for a web site or place that sells new built engines and transmissions that are comparable with my car.
Old Jan 21, 2012 | 05:44 PM
USMustangC's Avatar
USMustangC
Compatible*
Old Jan 21, 2012 | 07:53 PM
jojobanks's Avatar
jojobanks
jegs, summit, etc. If you want something more custom it would be better to find a local engine builder to set you up. That way if there are any problems it's not a big hassle to get it fixxed. I'm guessing you're in the marine corps and stationed around camp lejeune (correct me if I'm wrong), but if this is the case then you should have no problems finding one in your area. If nothing else there are some good candidates in the fayetteville area.
Old Jan 21, 2012 | 10:31 PM
USMustangC's Avatar
USMustangC
Yeah I'm in camp Lejeune I was thinking of buying local but a lot o places here are shady so I try to avoid the area if I can. What would you consider a reasonable price for a new 302?
Old Jan 21, 2012 | 10:35 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
check out www.fordstrokers.com the owner of that site is a member here he can build to your tastes for your motor....
Old Jan 22, 2012 | 02:38 AM
andrewmp6's Avatar
andrewmp6
Engine depends you want stock or more power the trans depends on what you have auto or stick and how much power and do you want a overdrive gear or not.
Old Jan 22, 2012 | 07:19 AM
USMustangC's Avatar
USMustangC
I just want a stock replacement for the original the 302 and auto with an OD
Old Jan 22, 2012 | 08:17 AM
2+2GT's Avatar
2+2GT
Why not just rebuild the engine you have? Getting that rebuilt, since you already own it, should be no problem.
For and automatic overdrive, you should use a Ford AOD (Automatic Over Drive) transmission. These are well supported with conversion parts, you can basically bolt one right in.
If your 302 is trashed for some reason, and cannot be rebuilt, there are plenty of choices.
Old Jan 22, 2012 | 08:44 AM
USMustangC's Avatar
USMustangC
Thank you I will look into that transmission.
I would love to rebuild it since its numbers matching however I simply just don't have the time being in the military and prepping for a year deployment when I get back I'm also getting out a month after i return and headed to school.
Old Jan 22, 2012 | 12:14 PM
jojobanks's Avatar
jojobanks
you'll have plenty of time while you're deployed. Just drop the car/engine off before you deploy and pick it up when you get back. If it's a numbers-matching engine and you want to keep it that way then this is your best bet. You'll be able to get the trans done during this time as well.
If you live in the barracks or don't have your own house then you'll likely have to put the car in storage anyway. Be safe and keep your head down while you're out there.
As far as finding a place to get it worked on, I HAVE to believe that a few of your local marine buddies around base have some classics/mustangs. Just figure out where they go to get their cars worked on. i can speak highly of epic motorsports and force-fed performance, but they generally deal with subarus/evos. Just ask around. You'll find a good shop.
