AOD NOT SHIFTING RIGHT
Old Feb 5, 2012 | 02:47 PM
Jason Jones's Avatar
Jason Jones
Default AOD NOT SHIFTING RIGHT
I have a 1966 mustang just swaped in motor and tranny from 1989 crown vic.I went with a 4 barrel holley carb got the tv cable all hooked up and adjusted.Changed tranny fluid and filter.The motor runs great but the car will shift to 2nd gear and no farther it doesn't slip or anything it just acts as if you have manually shifted it and you haven't shifted any more.I did pull the governor and clean it it was a little dirty but not bad. when I changed the fluid it wasn't dirty and didn't smell burnt and no shiny stuff.Any ideas should I have pulled the valve body too and cleaned.Please help this thing is starting to get under my skin I have never had anything that I couldn't figure out until now so this is really bothering me.
Old Feb 6, 2012 | 12:15 PM
69thunder's Avatar
69thunder
I found this for you. I hope it helps you.
Replied on October 16, 2009
Tech Bulliten as follows.
AOD TRANS NOISE/DELAYED SHIFTS/OR NO ENGAGEMENTS TECHNICAL SERVICE BULLETIN Reference Number(s): 91-3-9, Date of Issue: February, 1991 Related Ref Number(s): 91-3-9 ARTICLE BEGINNING APPLICATION 1990 Bronco, Cougar, Crown Victoria, E-150, F-150, F-250, Grand Marquis, Mark VII, Mustang, Thunderbird & Town Car SUBJECT AOD Transmission Noise, Delayed Shifts or No Engagements REFERENCE Ford Motor Co., Technical Service Bulletin, No. 91-3-9, February, 1991 CONDITION & CAUSE Some 1990 Bronco, Cougar, Crown Victoria, E-150, F-150, F-250, Grand Marquis, Mark VII, Mustang, Thunderbird and Town Car vehicles equipped with the AOD transmission may exhibit transmission noise, delayed shifts or no engagements. This condition may be caused by an internal thrust washer that is abnormally worn. This wear results in virtually undetectable non-metallic particles that can plug the filter, creating fluid starvation. This could burn the fluid overdrive band and/or forward clutch plates. REPAIR To repair this condition, perform the end play check on the converter. If necessary, replace the converter, flush the cooler lines and replace the transmission filter. Refer to the following procedure for service details. CONVERTER END PLAY / ONE WAY CLUTCH CHECK 1. Insert the End Play Checking Tool (T80L-7902-A) or equivalent into the converter pump drive hub until it bottoms. See Fig. 1 . Expand the sleeve in the turbine spline by tightening the threaded inner post until the tool is securely locked into the spline. 2. Attach Dial Indicator (TOOL-4201-C) or equivalent to the tool. Position the indicator button on the converter pump drive hub and set the dial face at zero. See Fig. 1 . 3. Lift the tool upward as far as it will go and note the indicator reading. The indicator reading is the total end play which the turbine and stator share. 4. Replace the converter unit if the total end play exceeds the limits indicated in the following Converter End Play Specifications Chart
5. Loosen the threaded inner post to free the tool and remove the tool from the converter. CONVERTER REPLACEMENT & OTHER SERVICE REPAIRS 1. If the thrust washer is worn, the used condition allowable limit of .050" (.013mm) maximum will be exceeded. If this occurs, replace the converter. 2. To prevent repeat repairs, perform a thorough flushing of the cooler lines. Replace the transmission filter (E1AZ-7A098-A). Set the TV pressure with a pressure gauge to specifications.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
