stock engine specs
Old Sep 14, 2005 | 06:36 PM
KBunny's Avatar
KBunny
Default stock engine specs
Hey, I was wondering if anyone knew the details on a stock 289 2 barrel? I'm talking more of what was the compression ratio, what the stats on the 2v heads, what was the stats on the camshaft and such. I'm trying to figure out what im improveing on when I upgrade something. like if I have a longer duration or if im getting better intake on the new heads and so on.
Old Sep 14, 2005 | 09:02 PM
6mustang6's Avatar
6mustang6
Default RE: stock engine specs
Get service manual....... it has everything youi could possible need.
Old Sep 14, 2005 | 11:10 PM
pak133's Avatar
pak133
289
Bore and stoke 4.00 X 2.87
200 Horsepower w/ 282 ft-lb torque
Two barrel Ford carb
Hydraulic camshaft
In 1964, the 289 was available at 210 horsepower, four barrel carb, cast iron intake manifold and compression ratio of 9.0:1
In 1965 the 289 became was now at 225 horsepower, larger four barrel carb and a compression ratio of 10.0:1 This engine was available till the 1967 model year.
In 1968, the engine was reduced to 195 horsepower.
Old Sep 15, 2005 | 01:43 AM
KBunny's Avatar
KBunny
ok, ill go get a manual to get more info... Is there any inperticular book thats better than the rest?
Old Sep 15, 2005 | 07:57 AM
Soaring's Avatar
Soaring
I ♥ Acer
What you really need is a factory shop manual. Here is one on CD that I will be getting soon as my old manual is all oily and torn.
http://www.1aauto.com/1A/CDManuals/F.../CD65MUS/41512
Old Sep 16, 2005 | 02:05 AM
KBunny's Avatar
KBunny
ok cool, thanks
drfister
May 3, 2018 10:38 PM
Spiral534
Oct 6, 2015 04:31 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Tyoung68
Aug 25, 2015 04:31 AM
