Need help - removing spring shackle
Old Feb 12, 2012 | 06:24 PM
Bosko's Avatar
Bosko
Question Need help - removing spring shackle
I'm changing the rear leaf springs in my 1971 Mach 1. I am struggling to remove the upper bushing for the spring shackles, the one in the frame. I have seen advice on line to use a torch and burn it out, but the fuel tank is only inches away so I do not want to do that for obvious reasons.
Has anyone done this before? How do you get the old bushings out?
Thanks!
Old Feb 12, 2012 | 07:42 PM
MonsterBilly's Avatar
MonsterBilly
Yes, I used a saws all and cut both sides. Then just worked it out
Old Feb 12, 2012 | 09:22 PM
Bosko's Avatar
Bosko
I've removed both sides of the "mushroom", but whats left will not budge. Did you drop your fuel tank so you could get a hammer or other tool in there? I think that may be part of my problem - I only have about three or four inches on either side to work with.
Old Feb 13, 2012 | 10:59 PM
Bosko's Avatar
Bosko
Got 'em out tonight. Damn they were ornery! I was able to eventually hammer a pry bar into them, then lever them out.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
mungodrums
Sep 28, 2015 10:54 PM
