Dome light install
Old Mar 7, 2012 | 10:07 PM
oxfordbp's Avatar
oxfordbp
Default Dome light install
The last owner installed a nice new headliner without a dome light.
If I buy the kit, is this something I can install without removing my headliner? I can feel the two screws for the base but im more concerned running the wire.
The kit shows a single wire from the base with a male connection on the other end. Where does it hook up?
http://www.cjponyparts.com/scott-dra...7-1970/p/DLA2/
Old Mar 8, 2012 | 03:14 PM
emttrevor's Avatar
emttrevor
yes you can install without pulling headliner its safer to run the wire by removing the back seat, then cut the hole in the liner where the dome light will be get yourself a long piece of solid wire to use as a fish tape to run back to the quarter panel section and unclip the headliner from there its time consuming and you have to be careful but it can be done the red wire which will have to be extended will run down into the sill plate and you can cut and join the wire there if you dont have wiring in the sill plate then you will have to pull your door switches and join the wire in there...you can also be lucky and find that the wire is already run to the dome light , Ive gotten lucky a few times where people have put new headliner in and not put dome light back so the wire is still there but take your time or you will tear the liner
Old Mar 8, 2012 | 03:36 PM
oxfordbp's Avatar
oxfordbp
Great thanks. Where should he wire connect? I dont quite get that. What part is the sill plate?
Old Mar 8, 2012 | 03:45 PM
emttrevor's Avatar
emttrevor
not sure of your model but on the 67 the door switch wires run inside the sillplate which is the chrome plate that runs at bottom of the door when you open it it covers the carpet edge and the sill itself, it runs the whole length of the door opening either way the plate will have to come off to run wires to the door switch itself if you have to go that far with them.. also before you buy the dome light make sure you have the door switches intact otherwise you will need to get them as well
Old Mar 8, 2012 | 05:06 PM
oxfordbp's Avatar
oxfordbp
So it actually runs from the rear quarter to the front and hooks to the door switch. Are the two door switches hooked together then?
Old Mar 8, 2012 | 07:58 PM
emttrevor's Avatar
emttrevor
yes they are hooked together, now thats how I do it you can also follow the instructions on cjponies website and do it that way also it makes the run shorter for the wiring but I just didnt like the idea of putting a hole in the headliner where they suggest but either way will work just read their directions and choose the way you think will be the best for you
Old Mar 8, 2012 | 08:01 PM
emttrevor's Avatar
emttrevor
let me rephrase that they are hooked together under the drivers side where the harness meets under the kick panel which is the plastic panel to the left of your feet under the dash area
Old Mar 8, 2012 | 08:05 PM
oxfordbp's Avatar
oxfordbp
Cool man! Thanks for the great info!
djbigskrilla
Sep 20, 2022 01:04 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 21, 2015 04:01 PM
Soldier GT
12
Aug 20, 2015 09:42 AM
jjwinel78
Aug 17, 2015 03:34 PM
