disc brake help
Old Sep 16, 2005 | 03:17 PM
eZ's Avatar
eZ
Default disc brake help
i ordered a disc brake kit fromm ss brakes...great kit, but i did not order the power disc brakes. what do you guys think? should i send them back in exchange for the power disc brakes?
Old Sep 16, 2005 | 03:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: disc brake help
I forgot what year Mustang you have eZ. If it's a 64-66 you won't need the booster, but from 67-73 they are a big help because more weight was added to the body, engines, etc.
Old Sep 16, 2005 | 07:09 PM
eZ's Avatar
eZ
what is the curb weight of the 64.5? you dont think ill need a booster with around 350 horse?
Old Sep 16, 2005 | 07:57 PM
66 Hardtop 5.0's Avatar
66 Hardtop 5.0
IMO you dont need the booster. Actually doing the same conversion myself
Old Sep 16, 2005 | 10:03 PM
69mach1377's Avatar
69mach1377
Manual disks up front are just fine for my 69...much better than drums, so give em a try.
Old Sep 17, 2005 | 12:55 AM
eZ's Avatar
eZ
ill keep the manual brakes i already have...i looked up the curb weight of a 65 mustang...2556 lbs.
wow...my car is going to haul ***!
Old Sep 17, 2005 | 01:02 AM
Scott H.'s Avatar
Scott H.
Hi eZ,
If you don't like the feel, you can always change the bore size. And if you still don't like it, you can add a booster anytime.
Are you planning to do any open track or Auto-x events?
Old Sep 17, 2005 | 01:04 AM
eZ's Avatar
eZ
scott...i doubt it...i may do some of that with my 2000 gt
the 64 is for cruisin and for the 1/4 mile...i got bout 350 horse and ill be adding nos!
Old Sep 17, 2005 | 01:31 AM
Scott H.'s Avatar
Scott H.
ORIGINAL: eZ
It's going to haul more *** than a rickshaw with Jenifer Lopez in it!!!
You're going to run some drag radials right? Even if you only do a 100 shot, it's going to take some serious traction to hold that much power back.
That is going to be real exciting. Make sure you use good hog rings on the bottom seat cushion so you don't suck the cover up your "you-know-what" when you light the fuse on that puppy.
Old Sep 17, 2005 | 02:44 AM
eZ's Avatar
eZ
yeah im going to run some dr's your damn straight!!!
need to buy some 15' rims for the rear though but i got the hook ups for tires out here
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
