Overheating issues.
Old Mar 20, 2012 | 02:07 PM
guitarman376's Avatar
guitarman376
Be sure that it is indeed your radiator. My car's cooling problems were caused by debris in the cooling passages, which I didn't find out until I bought an aluminum radiator and it made no difference!
Old Mar 20, 2012 | 02:20 PM
oxfordbp's Avatar
oxfordbp
And how did you fix your issue?
Old Mar 20, 2012 | 03:46 PM
guitarman376
Well I had the motor stripped and boiled of course! The thing about my car's cooling issues was that the issue would only pop up every now and then. I suspected that the passages were so clogged that debris was building up then breaking apart, causing the car to run hot, then normal, then hot. I of course flushed the system for days with chemicals and distilled water etc but it made no difference. As soon as we saw what was behind the freeze plugs we knew it was time for it to be boiled. Since then, it has been running incredibly cooler. Expensive fix though, for sure.
Old Mar 20, 2012 | 04:06 PM
oxfordbp's Avatar
oxfordbp
Wow. If I had to go that far, I think it would be time for an upgrade! lol
Old Mar 20, 2012 | 09:36 PM
302blue66's Avatar
302blue66
Originally Posted by TomKat
well for 220 for me wasn't the problem the idea of it overheating was... so i paid the price its good quality id rather spend more $ to have it last and work properly and why go cheap on your classic car its investment my 2 cents
I just don't care to spend much money on my pile of crap.
I suppose there's a slight possibility that could be my problem. How could I go about checking for this issue?
Old Apr 1, 2012 | 10:52 PM
302blue66's Avatar
302blue66
So I took off my radiator and flushed it out a few times, then changed the oil and spark plugs, and now when I'm driving and I press the gas more than half way it starts sputtering and won't make power. What could be causing this?
Old Apr 1, 2012 | 11:12 PM
oxfordbp's Avatar
oxfordbp
Did you swap a few wires?
Old Apr 1, 2012 | 11:19 PM
302blue66's Avatar
302blue66
No, I took them off and changed the spark plugs one at a time
Old Apr 2, 2012 | 02:37 PM
abrush's Avatar
abrush
Had the same problem here and also had to have my engine boiled. It runs so cool now that it won't top 180 in 100 degree weather. I do have an aluminum radiator and Edelbrock high flow water pump which I think helps quite a bit.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 29, 2015 09:18 PM
MusicCity615
Sep 12, 2015 07:05 AM
