PCV and Breather
Old Apr 2, 2012 | 10:11 PM
Starfury's Avatar
Starfury
Nope, either side is fine. Same goes with the carb connection, although I don't recall my Eelbrock having a rear port.
Old Apr 2, 2012 | 10:34 PM
oxfordbp's Avatar
oxfordbp
I found out the rear port is for power brakes! I will just plug that and use the front PCV port!
Thanks for the info! I cant wait to get this running again! 2v to 4v plus a stealth intake should really change the feel!
Old Apr 4, 2012 | 09:59 AM
frdnut's Avatar
frdnut
You can use any big vaccum port..Don't feel that the rear port is just for power brakes..You will probably get a cleaner look if you go from the rear port and over to the passengers side valve cover like the factory did it..
Old Apr 4, 2012 | 10:07 AM
oxfordbp's Avatar
oxfordbp
Really!? I can use the rear port on the carb? I would like to hide as much as possible. The front port is labeled for the PCV that's why I thought "only" the front.
Old Apr 6, 2012 | 11:25 AM
kenash's Avatar
kenash
I got one with a 90 in it! thanks. Do you know where it should hook up on an edelbrock 1405? Front or rear?
Hi,
The proper location is the front center port. Those on either side are dizzy vac ports.
A side benefit of running a good PCV system is it reduces any tendencies for the block to seep oil, as well.
Oct 26, 2015 05:01 PM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
