which starter should i be using
Old May 7, 2012 | 07:31 PM
MonsterBilly's Avatar
MonsterBilly
Default which starter should i be using
I have my factory 289 with a t5 and t5 bell housing. And a 157 tooth flywheel.
I have been having starter issues and I think I may have the wrong part.
Old May 7, 2012 | 09:43 PM
Coupe's Avatar
Coupe
I used everything from the fox donor car, even the mini starter.
I did rebalance my flywheel tho.
Old May 10, 2012 | 11:53 AM
OCHOHILL's Avatar
OCHOHILL
Did you use the block plate for a T5? It is a piece of sheetmetal that goes between the block and bellhousing.
A C4 auto starter works on a T5 too.
Old May 10, 2012 | 02:44 PM
Iskwezm's Avatar
Iskwezm
I used the same starter from my c4
Old May 10, 2012 | 07:06 PM
MonsterBilly
well I was sking because i have been having starter issues for a while now. I have gone through everything. I finally settled on crappy made in China starters from O'rilleys. Monday was the third starter in 1 month. I thought it may be the bolts that were letting it move but it turned out to be the starters. I also think that my headers come really close to it so the starter may be getting too hot.
I will wrap the headers to help. They are the Jet coated headman headers. I though the Jet coating was supposed to help keep the heat out and away from under the hood but I guess it can only do so much.
Old May 10, 2012 | 09:50 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
go to the junkyard and pull a mini starter off a newer ford(or buy one) from like a 91+ towncar mustang etc...that will give you a little more room for airflow etc
Old May 10, 2012 | 10:41 PM
Iskwezm's Avatar
Iskwezm
i used to have the same issue.I replaced the starter about 15 years ago with a rebuilt Kragen brand.No issues since.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
