Coolant leak
Old May 12, 2012 | 04:46 PM
Stangman70's Avatar
Stangman70
Default Coolant leak
Hey guys I have what appears to be coolant coming from the top of my breather caps on both sides of the engine. I think this was caused by the improper installation of intake manifold gaskets.
I would have used the search function and looked around but it seems to have changed and will not let me search for topics.
Thanks.
Old May 12, 2012 | 05:28 PM
Iskwezm's Avatar
Iskwezm
so you have coolant coming out of both of the valve covers? Pull your dip stick and check for foamy milky looking oil.
Old May 12, 2012 | 05:31 PM
Stangman70's Avatar
Stangman70
Oil is dirty, but not brown or foamy.
Old May 12, 2012 | 06:19 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
go to autozone and get the loan a tool to pressurize your cooling system...
Old May 13, 2012 | 06:17 AM
kenash's Avatar
kenash
Thanks.
Hi,
Are you sure, what you are seeing is not blow-by vapors? This is much more common than coolant.
Good Luck!
Old May 13, 2012 | 08:54 PM
Stangman70's Avatar
Stangman70
Kenash, I am pretty sure its not just vapor I have fluid spitting out from my breather caps. The fluid felt thin, but not oily, and took a while to dry on my finger. It also smelled sweet, which is why I am pretty sure it is coolant. I will take rmodel's advice and try to pressurize the coolant system.
Old May 13, 2012 | 09:23 PM
kenash's Avatar
kenash
Hi,
OK, do the pressure check. Do the test with a warm engine. Remove the rad cap and create the pressure. Look for the leaks around the heads, and bubbles in the coolant fluid. Since it's showing in the V/C by virtue of blow-by in the case, it may be very tiny, as you are not seeing it in the exhaust? Correct?
Good Luck!
Old May 13, 2012 | 10:19 PM
Stangman70's Avatar
Stangman70
You are correct I am not seeing any in the exhaust. Thanks for the advice I will keep you posted.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
