Engine Block Numbers Help needed!!!
Old May 12, 2012 | 07:35 PM
Duhner's Avatar
Duhner
Default Engine Block Numbers Help needed!!!
I just bought a 1969 mustang and a 1977 mustang 2. I got two for a reasion lol, he had tryed to put a new 302 and c4 tranny in to the mustang two and it did not work. So he stoped working on both car and they sat, Untill i came along. There was no motor for the 69 and he convinced me to buy both and put the new motor and trans in the 69, after looking at both i bougth them and went to work. After pulling the motor and painting it i put it in to the 69 the pulleys were wrong on the motor, he tyred to use the 77's pulleys so off they went. I got ahold a guy with the right pulleys and he came over and check my motor to see what would fit. Told me i was right with the pulleys and said the harmonic balencer was wrong too, thinks its the wrong weight too. So Ive tryed to find an engine block date to make sure the weight due to 1980 and lower uses 28 and 50 for 1981 and above. I cant find the engine numbers there not by the starter like they should be. I did find a rebuild number but dont know who rebuild it. Is there other places I can find a date just to make sure i have the right weight? Thanks
Old May 13, 2012 | 02:01 AM
oxfordbp's Avatar
oxfordbp
Did you look above the starter? Take it out and you should see them hidden by the starter.
Old May 13, 2012 | 07:04 AM
2+2GT's Avatar
2+2GT
If the starter was installed there's no way to see them. The date code is the smaller numbers next to the block code.
Old May 13, 2012 | 09:01 AM
Duhner's Avatar
Duhner
Yes I did look were the starter is at and nothing. Why im asking if theres any more places were i can find a date of the block to get the right harmonic and flex plate weight.
djbigskrilla
Sep 20, 2022 01:04 AM
SANDY21
Aug 17, 2015 02:41 PM
defarmer
Aug 13, 2015 06:40 AM
classic69FB
Aug 12, 2015 11:58 PM
