Carb and intake swap
Old May 30, 2012 | 02:27 PM
paddy187@hotmail.com's Avatar
Default Carb and intake swap
Folks,
Back to the forum after a long time a way........ I am building up a parts list before I change my intake and carb on my 289 as getiing parts can be a pain in the netherlands. I am changing my 2v stock 2100 to 4100 with a wieand steath intake so far I have:
Intake
Intake gasket set.
Carb (autolite 4100)
Intake bolts
Thermostat housing and gasket
RTV Blue
heater hose elbow
temperature sensor
on order is a holley universal carb install kit
Is there any thing else I need before I start the swap other than mechanical talent...
Cheers
Paddy
Old May 30, 2012 | 02:30 PM
forgot to add my current carb has no choke so what will I need to get this up and running on the 4100
Old May 31, 2012 | 08:06 AM
kenash's Avatar
kenash
Hi,
You will need a choke cable assembly. Most all of the big box mustang suppliers carry a retro looking cable. I ran a 1405 Edelbrock for a number of years on my early 65 and used an early Shelby cable.
But, I'm thinking any of your local auto supply stores will carry a generic cable. There's not much to them.
Happy Motoring!
Old May 31, 2012 | 01:21 PM
musnicki's Avatar
musnicki
Are the gas pedal linkages the same for both carbs? And do you run any vacume hoses off of your current carb?
James
Old May 31, 2012 | 03:36 PM
I thought the 4100 had auto choke with tube from the manifold?
I am thinking the gas pedal linkages are the same, famous last words...I will double check. As for vacuum from the carb is to the distributer, spacer has PCV vacuum and manifold has vacuum to transmission.
uberstang1
Sep 20, 2015 06:42 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Wombatnation
Sep 13, 2015 09:16 PM
tramphardrocker
Sep 13, 2015 08:56 PM
vintageaion
Sep 8, 2015 10:45 AM
