better rear shocks
Old Jul 1, 2012 | 04:31 AM
MonsterBilly's Avatar
MonsterBilly
Default better rear shocks
I am currently running the kyb gr2 shocks all the around but i would like to stiffen up the rear some. Will the regular kyb shicks do it or is the a different option i should be looking into. I dont want ro spend a ton but i dont mind spending money for a good product.
Old Jul 1, 2012 | 06:36 AM
2+2GT's Avatar
2+2GT
I have the Kayaba Gas-A-Just all around, and I like them.
Old Jul 1, 2012 | 10:32 AM
Starfury's Avatar
Starfury
First question, why do you want to stiffen it up?
I started out with Gas-A-Justs and, while they handled well and I was happy with them overall, they didn't ride very well on rough pavement. They were stiff enough to cause the rear end to bounce and skitter around rough corners. I switched to Edelbrock IAS shocks and am much happier with them. They control body roll just as well as the Gas-A-Justs, but they ride much, much nicer due to the variable valving in the shock.
However, if you're going to spend the money on some Edelbrocks, you may consider forking the extra bit for some custom-valved Bilsteins from Street or Track. I've heard nothing but good things about those.
Old Jul 1, 2012 | 02:45 PM
MonsterBilly
well it bottoms out really easy with only me in the car. When i hit the bumps over the intersections i bottom out. I have the 4.5 mideye springs as well. I also have a lot of body roll and when i take off with a fast launch the *** end sinks a ton.
the ride is decent but i think it is a little soft.
MonsterBilly
I am really happy with the front though
Old Jul 1, 2012 | 03:43 PM
Starfury's Avatar
Starfury
Interesting. How old are those springs?
Old Jul 2, 2012 | 12:20 PM
MonsterBilly
not very old. i installed them when i redid my car about 4 years ago. they have about 6-7k miles on them
Old Jul 2, 2012 | 04:42 PM
Old Mustanger's Avatar
Old Mustanger
I would recommend the Koni yellows if they are available for your year Mustang. You can run them full soft, then adjust them a little at a time to get exactly the ride you want.
I use them on my '97, now I will never use anything else.
guitarman376
Oct 11, 2015 01:47 AM
KingRando
Oct 1, 2015 11:16 AM
67STANGX2
Sep 24, 2015 12:29 PM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
