damper/ harmonic balancer
Old Jul 19, 2012 | 05:51 PM
oxfordbp's Avatar
oxfordbp
Default damper/ harmonic balancer
Can I replace this without taking apart most of the engine? I know I willo have to take the lower pully and stuff off.
Thanks
Old Jul 19, 2012 | 08:39 PM
Coupe's Avatar
Coupe
On what?
I will guess a 302 since thats whats in your sig line, but yes remove the pulley and then the big bolt in the center of the balancer. Sometimes they just pull off but most times you need a puller that bolts into the holes the pulley used for mounting, never use a jaw puller ad it will pull the outer ring off.
Old Jul 19, 2012 | 08:56 PM
oxfordbp's Avatar
oxfordbp
Originally Posted by Coupe
On what?
Yes 302. Thats what I thought, just needed to make sure.
Can you help me decide on a balancer. I dont want anything expensive, stock or just over stock is good. Mine is old and I can see it jumping when trying to time it. I believe it is the 28oz. 70's block non roller
Old Jul 20, 2012 | 02:15 PM
Coupe's Avatar
Coupe
I would not spend big money on an SFI rated piece unless I was going to be on the track a lot, Summit has some that are quality at the same price as the repop stock balancer.
And yes, it sounds like a 28oz balancer.
Old Jul 20, 2012 | 05:53 PM
oxfordbp's Avatar
oxfordbp
Something like this?
http://www.summitracing.com/parts/SUM-163289/
mtgldr
Feb 3, 2024 09:00 PM
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 8, 2015 11:50 AM
Urambo Tauro
Aug 27, 2015 10:53 AM
