Speedometer Problems
Old Jul 26, 2012 | 08:43 PM
beatlesrcool1964's Avatar
beatlesrcool1964
Default Speedometer Problems
Hi all,
I'm almost finished with my project of five years and just ran into another problem I can't solve myself.
My speedometer has stopped working.
I tried uninstalling the speedometer cable from the back of the gauges. When I did, the square inner metal cable was easily spun and could be pulled out without a problem. I adjusted it and pushed the cable in, and the cable would not spin. I thought this fixed it and reinstalled. I drove the car and the speedo seemed to work.
I went to the store and the speedo worked the whole way. When I drove back home, the speedo no longer worked.
Do I just need to buy a new speedo cable or is this fixed some other way?
Thanks.
66 Mustang 200 ci with A/T
Old Jul 27, 2012 | 02:34 PM
jlg2002's Avatar
jlg2002
You may want to check the trans gear just to make sure it's ok and mounted correctly on the end of the speedo cable.
Old Jul 27, 2012 | 03:05 PM
beatlesrcool1964
the gear is fine and completely intact. it appears to be mounted correctly.
Old Jul 30, 2012 | 02:44 PM
jlg2002's Avatar
jlg2002
If the shaft is turning and there is no indication, the speedo head is defective (since you've stated that you've checked the gears installation). If the shaft is not turning - you''ll have to figure out why. Recall it's all one piece and unless it's broken, it should be turning.
Old Jul 30, 2012 | 11:02 PM
beatlesrcool1964
I ended up replacing the speedo cable and it all appears to be working well. Also, the speedo is more stable. It was wobbly before.
articman
Jun 21, 2018 11:45 PM
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
