seat pan ?
Old Jul 27, 2012 | 05:31 PM
oxfordbp's Avatar
oxfordbp
Default seat pan ?
What is the difference between the one piece pan and the separate seat pans?
Doe they have the same mounting holes?
I would think the one piece would be easier to install.
Old Jul 27, 2012 | 06:52 PM
2+2GT's Avatar
2+2GT
Yes, the one-piece, the way Ford assembled it, is easier, because although the spot welds for the pinchweld at the rocker, firewall, and transition are the same either way, with the two side pieces you also have to weld nearly ten feet of the transmission tunnel with the two piece. And, of course, the results with the one piece are superior.
There are several cars with the one-piece shown here-
http://www.mustangbarn.com/
Old Jul 27, 2012 | 09:23 PM
oxfordbp's Avatar
oxfordbp
Great thanks. The 66 im getting has them taken out. are there dimensions somewhere so I can make sure I put it in the correct place. the stock seating is perfect for me as im only 5'8"
Old Jul 28, 2012 | 08:46 PM
2+2GT's Avatar
2+2GT
On reviewing this thread, I realized you were talking about the seat platforms. The one-piece is a convertible item which adds stiffness to the car. Dynacorn also uses it in at least some of their faastbacks.
Old Jul 28, 2012 | 11:54 PM
oxfordbp's Avatar
oxfordbp
So I should use the separate ones? Im thinking of finding a bench seat to istall, any one better than another?
Any instructions on installing these to my floor pan?
Old Jul 29, 2012 | 09:35 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the holes for the seat bolts will be directly above the access holes in the floorpan you use to get to them so you can use that as a guide for lining them back up
Old Jul 30, 2012 | 01:13 AM
oxfordbp's Avatar
oxfordbp
Great thanks!
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
