springs between door and door panel
I have 2 springs for each door that go between the door and the door panel. One of the springs is longer (has more coils) than the other one. Does anyone know which spring is for the door handle and which is for the window crank? Thanks.
The door handle escutcheon or spring on CJ Pony's WWW p/n HW 289 has 5 coils, I couldn't find a window crank spring. Below is what Ebay has but take Ebay with a grain of salt.
4 pc inside door & window handle escutcheon tension springs quarter crank spring (Fits: 1965 Ford)
Thank you. I think I figured it out by looking at the markings on the old door panel. It seems that the spring with more coils actually is for the window crank and the other spring is for the door handle which makes sense since more work is required to roll the window down. Springs and panels are installed and all is working well.
