65 Mustang dimensions
I have seen and have two different Mustang frame dimension sheets. One from the internet and one from my Falcon Mustang book. They are not the same. One said the front frame rail is to be 13 3/8 from bottom of front rails to datum and the other said 10.5 inches from datum to bolt hole for front bumber. they also show different dimensions for other parts of the car. One said 30 inches between the front floor suppos and the other is alot closer. I need the real true dimensions to put thic car back together correctly. I have to put in a new cowl, firewall, side cowl panels, all four engine bay aprons, half the front right frame rail and a shock tower along with radiator support asembly. Along with full floors and trunk and right side rear frame rail and torque box and other miscellanious parts. The old stuff was so rotted you could not get any good measurements off of it. Could some please tell me what the right dimensions are and if you have built a cradle to set the car on what were the actual dimensionsl of it. Pictures would help. Thanks looking forward to everyones input.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
