68 MUSTANG HOOD STUCK SHUT
Old 10-06-2012, 06:32 PM
Ivan.Cagle89D
Ivan.Cagle89D's Avatar
Default 68 MUSTANG HOOD STUCK SHUT
hey guys, i have had a heck of a time trying to get this open, and decided its time to call in the big dogs.... i have the hood latch without a cable, that you just go under and lift it right up... problem is the hook that latches under the catch rod, the spring came off and now that part isnt moving... and the hood won't come open... myself and THREE others have tried getting a screwdriver in there at differant angles trying to pop it and it just won't work.... so then i tried to just unbolt the mount all together and lift it up.... then i ran into the problem that the two bolts at the top are where i cant get to them.. so i'm stuck... any suggestions?
Ivan.Cagle89D is offline
Old 10-07-2012, 03:11 AM
musnicki
musnicki's Avatar
Squirt some lube up there?
There are two bolts that hold down an L shape metal rod that your hood latch secures to. The L shape peice is secured to a support peice that reinforces the grille as well. That piece is held down by four big 1/2" bolts to the grill and front frame support. Also, if you have a metal Mustang in your grille there will be three small nuts attached as well.
You could try to take off the latch from the hood or jack the car up to get a better view. I would go with some kind of spray lube though.
musnicki is offline
Old 10-07-2012, 07:50 PM
2+2GT
2+2GT's Avatar
The spring does not pull the release, so lack of it doesn't matter. Something else is wrong.
2+2GT is offline
landomar2014
08-17-2015 04:27 PM
MustangHead91
08-16-2015 03:20 PM
jdphillips73
08-15-2015 04:12 PM
daytooday
08-11-2015 09:22 AM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
Quick Reply: 68 MUSTANG HOOD STUCK SHUT
