clutch conversion
Old 11-02-2012, 09:49 AM
ColtonS3290
ColtonS3290's Avatar
Default clutch conversion
I have a 71 mustang with a 69 351w, 91 T5 Trans with conversion kit to 69 bellhousing, I'm not sure what clutch setup I need. It's cable clutch but not sure if I need 91 clutch setup or 69 clutch or if it even matters at all? Any advice will be taken. (first rebuild and conversion) thank you
ColtonS3290 is offline
Old 11-02-2012, 10:36 AM
paulo
paulo's Avatar
As I understand you can use the 69 setup with the adapterplate setup. SO you should be good if you have all the linkages and ect. The issue may be if the cable setup was not made for an old mustang as I understand. Added note: If using a new bellhouseing, then there is something that bolts to the bellhousing (not adaptor plate) that allows you use old clutch setup . Or you can use a new bellhousing with a new clutch setup. Another note, some of the cable setups get in way of headers. I will be putting T5 in my car next week so I will know if all I read is true lol.
paulo is offline
Old 11-03-2012, 02:07 AM
andrewmp6
andrewmp6's Avatar
I would call moderndriveline.com he knows his stuff and he only does tran swaps in early mustangs.
andrewmp6 is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: clutch conversion
