Belt / pulley challenge
I have a 1965 Mustang with a 302 engine. Im having bit of belt/pulley problem when trying to install a power steering pump.
Basically my question is:
Can a serpentine belt pull the alternator over the water pump pulley or is it best to route it from both the water pump AND crank?
Said in another way, can I run the alternator as this:
water pump - alternator
or is this routing required:
crank - water pump - alternator
The reason I ask is to find out if I need a dual pulley for both the crank and the water pump or if a dual pulley for the water pump only will suffice.
autoedit
Sep 27, 2015 06:37 PM
