Disc brake conversion question.
Because you can get a factory KH-style setup for $600 that doesn't require changing spindles and doesn't mess with the steering geometry (Granada spindles have different steering arm geometry that can cause bump steer issues). It also makes getting replacement parts much easier; you simply walk into your nearest parts store and ask for parts for your year car, instead of trying to remember what year Granada you pulled which part off of.
Interesting comments...especially since I'm just about to install a CSRP front disc kit on my '65. I had to go with the CSRP "Granada"version of the kit, since my original spindles were ruined by a PO who welded...yes, WELDED...a set of Oldsmobile calipers to them in a "Frankenstein"conversion using rotors off the rear of a 1996 Mustang and Olds calipers!! The car stops...but not very quick.
anyone know of any significant bumpsteer issues with the CSRP kits?
If one jumps through many hoops, can put up with all the parts to change (Know which pieces to Fit), have a OLD School guy that will take the time to Align the car, And you Pay the exttra cost to do these thinks yes they will work fine.
A Dodge truck spindles will work fine on a early Mustang, if you have mechanical skills.
Dan @ Chockostang
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
