rivet removal inside rocker
Old Oct 22, 2013 | 01:22 PM
groho's Avatar
groho
Default rivet removal inside rocker
Crazy question, pulled my rocker panels in preparation for paint on my 66 coupe, and removed the molding hardware so I can replace with new hardware after paint. Realizing the old rivet heads dropped into the rocker, does anyone have a good idea how to remove those loose rivets to prevent them from rattling around inside the rocker? The only idea I have is to drill the inner rear fender covering the rocker for access. Any ideas out there that are less time consuming?
Old Oct 22, 2013 | 02:26 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
personally i wouldnt worry about it...
Old Oct 23, 2013 | 02:43 PM
clowe1965's Avatar
clowe1965
Are they aluminum rivets? if not you might be able to chase them around with a magnet. You could also try using compressed air to blow the rivet from one end to another, then drill an access hole. slightly more obtrusive, but punching a hole and purchasing a rubber plug would allow professional looking access to that area in case something similar happened again.
jwog666
Dec 27, 2021 08:09 PM
Sixer4Life
Oct 12, 2015 04:26 AM
Dathan
Oct 5, 2015 05:52 AM
GLOCKer
Sep 28, 2015 07:36 AM
Sixer4Life
Sep 28, 2015 07:05 AM
