Rear Diff Question
Old Jun 9, 2014 | 01:34 PM
freddyb44's Avatar
freddyb44
Default Rear Diff Question
I have a 289, transmission and rear end all out of a 66 Mustang, or so I was told. Engine and transmission seem to be correct but the rear end, not so much. I can't find anything that actually tells me it is from a '66 Mustang, what size it is and so on. The only two things I know because I haven't pulled it apart yet (one drum is stuck due to rust) is that the axle has the two indentations like a 9" and it's case bolt pattern is round with 10 bolts. There is no ID tag on it, just one that says 3.22. I want to take it in to be rebuilt if needed, new seals and gaskets, gears checked, I can do the brakes myself but again, not knowing what it is makes it hard to call around. I have included a couple of pics I took last night, any help is greatly appreciated.
http://imgur.com/K6ikPsX
http://imgur.com/VdbIpl1
http://imgur.com/k4lelSH
If anyone wants more pics, I will get them later today.
Again, thank you.
Old Jun 9, 2014 | 03:00 PM
69mach1377's Avatar
69mach1377
What does the back side look like?
Old Jun 9, 2014 | 03:03 PM
barnett468's Avatar
barnett468
wow, that is but ugly. looks like a 50's to early 60's 9". as requested, need rear photo.
measure the width. it is most likely 1" wider than a mustang
Old Jun 9, 2014 | 03:06 PM
freddyb44's Avatar
freddyb44
It looks like this, exactly, no dimples, no hump, just round. Filler hole is on the bottom
http://static.speedwaymotors.com/RS/...t/715700_L.jpg
Old Jun 9, 2014 | 03:08 PM
freddyb44's Avatar
freddyb44
HA! It IS in bad shape, I want to love it though despite its flaws. I just put a picture of what it looks like, I can get another when I get home.
Old Jun 10, 2014 | 12:57 PM
69mach1377's Avatar
69mach1377
I think that's an 8 inch
Old Jun 10, 2014 | 01:31 PM
freddyb44's Avatar
freddyb44
Anyone know if I get the case out, will there be any markings that would help identify it, since I the metal tag is missing
Old Jun 10, 2014 | 01:51 PM
barnett468's Avatar
barnett468
IT WILL HAVE THE GEAR RATIO STAMPED ON THE CASE. THERE IS A DATE CAST INTO THE OUTSIDE OF THE PUMPKIN AND MAYBE A PART NUMBER.
Old Jun 11, 2014 | 07:09 AM
Al Newman's Avatar
Al Newman
If it is not a really early Ford, it is not Ford at all. Keep looking for a correct 1965-66 rear axle assembly.
Best,
Al
Tivo304
Aug 28, 2023 12:19 PM
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
