blinkers not working
Old Sep 28, 2014 | 04:27 PM
845frankm's Avatar
845frankm
Default blinkers not working
67 mustang headlights,parking lights,brake lights,4wayswork blinkers do not I noticed when I put the blinker switch on to go left the brake light goes out and same going right all fuses are good any help
Old Sep 29, 2014 | 10:27 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably a bad blink switch in the steering column
Old Oct 1, 2014 | 09:32 AM
bop11's Avatar
bop11
Try a new flasher. It is different than the hazard flasher. It is fed indirectly from the accessory terminal on the key switch via the fuse box but does not have a fuse. Black/green to fuse box (fuse feeds the backup lights only) and connected to the black/green the org/yellow to the flasher. In the column a blue wire goes to the 4 way flasher switch. From there it goes to the turn signal switch. The common of the turn signal switch is normally connected to both stop lights. When you move the turn signal lever, it disconnects the appropriate (left or right) stop light from the stop light switch and connects the flasher to the appropriate front and rear directional signal and brake light respectively. So that the flasher powers the turn signal.
Inside the flasher is a heater winding that bends a thermal strip. When you turn on a signal , the winding conducts through the turn signal lamps but the current is so low that the lights do not illuminate. Once the thermal strip is heated it bends and connects the signal lights, turning them on and shorting across the thermal winding allowing it to cool. If a bulb is burned out either the winding will not get hot enough to make the lights turn on, or will only get slightly hot, making the cool down cycle very short and the good light flashes very quickly.
So first check the front turn signal lights and rear stop lights, then replace the turn signal flasher.
Old Oct 2, 2014 | 08:47 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
That's some good poop.
Old Oct 2, 2014 | 08:45 PM
TomKat's Avatar
TomKat
try taking the light out and seeing if there is any dust in there sometimes disrupts the connection. if not then what ^^^^ they said
1TUFF302
Nov 5, 2015 04:02 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
