disc brake upgrade
Old Oct 6, 2014 | 01:48 PM
tom taras's Avatar
tom taras
Default disc brake upgrade
i have a 1966 mustang convertible-has anyone upgraded their mustang with disc brakes and if so, are you satisfied with the performance and the cost-thank you
Old Oct 6, 2014 | 02:13 PM
Starfury's Avatar
Starfury
Assuming you have a V8 car (or at least the V8 5-lug front end), this is a very common conversion.
I have the CSRP SWAP.1 kit on my '67 and I'm very happy with it. Installation was mostly bolt-on (the front brake hard lines require some adjustment or replacement), and I had it done within a day.
While stopping distance doesn't really change, driveability improves by leaps and bounds. Front drum brakes tend to fall out of adjustment periodically, causing a pull while braking (especially when braking hard). Disc brakes don't have this problem. They also fare much better than drums in wet weather, and are much easier to modulate than drums.
I was initially worried about pedal effort without a booster, but after driving I decided that it wasn't really needed. Pedal effort is higher than a modern vehicle, but not as high as the manual drums, and is plenty easy to drive with.
Old Oct 6, 2014 | 03:03 PM
Gun Jam's Avatar
Gun Jam
I have the SSBC front brake kit.
Easy to install
Reliable (10+ years daily driven no issues)
Provides excellent stopping power and never comes out of adjustment.
Is not power assisted and I too also do not believe this is necessary pedal effort is completely reasonable.
-Gun
Old Oct 6, 2014 | 03:17 PM
67mustang302's Avatar
67mustang302
Wilwood
Old Oct 6, 2014 | 06:01 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Granada swap w/no power assist.
20 years and counting.
Old Oct 7, 2014 | 06:24 PM
Iskwezm's Avatar
Iskwezm
I went with Master Power 13's in the front and 12's in the rear. I should or I NEED to have this stuff on before SEMA.I like the feel manual brakes so I kept that type.
Old Oct 11, 2014 | 09:59 AM
Boogie's_AutoRama's Avatar
Boogie's_AutoRama
Granada swap.
Power boost not needed.
Handles and stops great.
Old Oct 12, 2014 | 04:20 AM
tx65coupe's Avatar
tx65coupe
I have a manual Granada conversion as well. The appropriate master cylinder is key.
Old Oct 13, 2014 | 10:57 AM
fastbackford351
Foghorn Leghorn
I think the last time I replaced mine I used one from a mid-70's F150. Whatever it was had the same plumbing as the Mustang but with a larger reservoir.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
maestro1024
Sep 21, 2015 02:40 PM
uberstang1
Sep 21, 2015 09:04 AM
