converting a generator to an alternator
Old Apr 18, 2015 | 06:53 PM
Dale875's Avatar
Dale875
Default converting a generator to an alternator
I have a 64.5 mustang, 289 4v, 4 speed, ps, pb, and air conditioning. The generator is bad so I am thinking this is the right time to convert to a 1 wire alternator. I know that I will need new brackets but will the pullies line up and will I need to rewire anything
Old Apr 19, 2015 | 04:45 AM
67mustang302's Avatar
67mustang302
Pullies depends on your specific set up and alternator used. As for wiring, you need to disconnect the factory voltage regulator, 1-wires typically have the regulator built in.
Old Apr 19, 2015 | 01:50 PM
Dale875's Avatar
Dale875
Can I just tape up the wires running from the voltage regulator to the generator or do I need to remove them?
Old Apr 19, 2015 | 03:29 PM
67mustang302
I just taped up mine, and unplugged the regulator.
Old Apr 21, 2015 | 06:49 AM
Dale875's Avatar
Dale875
There are 3 wires that run from the solenoid to the generator, if I tape them up do I need to do anything to the voltage regulator?
Old Apr 23, 2015 | 09:41 PM
Dale875's Avatar
Dale875
My mustang has the big voltage regulator next to the radiator, the best I can tell there is nothing to unplug. There are some terminals that have wires connected to them, do i just disconnect them and tape them up?
Old Apr 23, 2015 | 10:59 PM
67mustang302
There should be a way to disconnect it.
Old Apr 26, 2015 | 04:29 PM
Dale875's Avatar
Dale875
Default brackets
I finally figured out the wiring to convert my car to an alternator and I bought a set of Mr gasket alternator brackets and I can't figure out how to install them and I see no place for the air conditioning pulley. Has anyone else had this problem and if so how did you solve it?
Old Apr 26, 2015 | 04:37 PM
Choppertwo's Avatar
Choppertwo
Damn , Gears just had a segment on the very same thing you are doing, sorry , I'm not that much of a gearhead, so Im not much help
Old May 7, 2015 | 06:21 AM
Dale875's Avatar
Dale875
Default no power
I finally got the alternator installed after getting the generator brackets modified, I taped up the wires that ran to the generator and ran the one wire from the alternator to the solenoid. I unhooked the biggest wire at the voltage regulator and taped it up and now I have no power, the lights won't come on, nothing. I charged the battery overnight so that's not it, any suggestions would be appreciated.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
