no juice
Old Jun 4, 2015 | 10:01 PM
Dale875's Avatar
Dale875
Default no juice
I have a 64.5 mustang 289 4v that I recently switched from a generator to an alternator and put in a new battery. It was running great until Sunday when I was going to take it for a spin and I had no power. Nothing would come on, no lights, radio, nothing. I have checked the wires running to the solenoid and the old voltage regulator that I have bypassed and can't find anything. Any suggestions or advice would be appreciated.
Old Jun 4, 2015 | 10:53 PM
jwog666's Avatar
jwog666
is the battery dead maybe? check the voltage it should be 12.6v for a fully charged battery
Old Jun 5, 2015 | 05:40 AM
Dale875's Avatar
Dale875
I don't think so, it's only 2 weeks old but I will check it
Old Jun 5, 2015 | 06:35 AM
jwog666's Avatar
jwog666
start with the basics, battery and alternator tests, its possible that you got a defective unit of either
Old Jun 5, 2015 | 07:59 AM
Dale875's Avatar
Dale875
Thanks I will
Old Jun 5, 2015 | 09:12 AM
bop11's Avatar
bop11
When you switched to the alternator, what did you do about the external generators regulator? Was the alternator a one wire type or was it from a later mustang which needs it's own regulator. Does your car have an ammeter or just a charge light?
Old Jun 5, 2015 | 11:44 AM
Dale875's Avatar
Dale875
I switched to a 1 wire alternator with a internal voltage regulator and bypassed the old voltage regulator
Old Jun 6, 2015 | 08:31 PM
Dale875's Avatar
Dale875
The problem was a bad battery clamp on the negative terminal
Nurdyguy
Jan 20, 2025 04:38 PM
jwog666
Dec 27, 2021 08:09 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
beezy
Nov 10, 2004 04:14 PM
Big5.0.13.7sec.
Nov 4, 2004 02:02 AM
