289 stutters under power
Old Sep 24, 2016 | 06:01 PM
16gillerya's Avatar
16gillerya
Question 289 stutters under power
so i was out cruising today and about 25 minutes into the ride the motor started to stutter under power ie going up a hill or just accelerating. I do not know weather this is an engine or a trans problem
it is a 65 mustang with a 289 and an fmx trans thanks
Old Sep 24, 2016 | 11:26 PM
347mav's Avatar
347mav
Sounds like a possible ignition issue. Check the basics. Distributor Cap,rotor, wires,plugs.
Old Sep 26, 2016 | 03:15 PM
67mustang302's Avatar
67mustang302
Could be a lot of things....but it all comes down to 3, fuel, air or spark. Bad cap/rotor, plugs, wires, coil, clogged fuel filter, trash in a carb, bad gas, too lean etc.
If it runs fine until the weather or engine temp changes then it's most likely a fuel ratio issue or weak ignition.
Old Sep 27, 2016 | 09:17 PM
16gillerya's Avatar
16gillerya
THanks guys
Old Sep 28, 2016 | 12:38 AM
Gun Jam's Avatar
Gun Jam
If its okay on flat ground but has issues under load its possible that it could be a fuel pump...Does it run strong at full accel from a dead stop to 70MPH+? If its badass through first gear but a few seconds into 2nd it falls on its face its most certainly fuel volume issue (secondary to fuel pump or fuel filter or line blockage)....If it pulls strong through all gears past 70mph...probably not a fuel pump issue.
Old Sep 28, 2016 | 07:47 AM
bop11's Avatar
bop11
Have you ever replaced the coil? May be a heat problem in the coil. Did it stutter all the way back home? Did it start the next day or an hour later and run OK for 20 minutes?
my65coupe
Sep 23, 2016 06:50 AM
Chris Hyer
Jul 16, 2016 05:26 PM
Jul 16, 2016 02:37 AM
Mustang Videos
Jul 15, 2016 12:15 PM
Jul 13, 2016 12:55 PM
