64.5 289d code electronic ignition
Old Dec 5, 2016 | 08:09 AM
johnrem46's Avatar
johnrem46
Default 64.5 289d code electronic ignition
I am in the process of installing a Pertronix electronic ignition. The car has a MSD installed on it (IT came with the car) .I am confused as to what wires need to stay. What advantage does the MSD provide? Would it be wise to disconnect it? or should I leave it and work out the wiring.
Old Dec 5, 2016 | 10:59 PM
Starfury's Avatar
Starfury
First question: why are you replacing the points?
With an MSD box, the points become nothing more than a switch to send signals to the box. They don't suffer the wear and tear they would under normal use.
Not to say a Petronix is a terrible idea; depending on the particular model, it would be replacing a mechanical switch with an electronic one, which might make ignition timing more precise, especially at higher rpm's.
MSD boxes provide a Multiple Spark Discharge, which helps with fuel ignition, particularly at lower rpm's and lower cylinder pressures. This helps with torque and throttle response.
Depending on which MSD box you have, some of them provide other features like rev limiters and launch controls.
Old Dec 6, 2016 | 10:16 AM
69mach1377's Avatar
69mach1377
It's not clear what MSD components the OP has...
Old Dec 6, 2016 | 05:32 PM
johnrem46's Avatar
johnrem46
I was under the impression that the pertronix was better than points. After reading you response I am not so sure. I do not know what MSD I have. Can I nleave the MSD and add the pertronix??? or just stay with the points???
Old Dec 7, 2016 | 08:40 AM
69mach1377's Avatar
69mach1377
Are you saying you have an MSD distributor? Or a complete system? Get rid of the points unless you enjoy messing with them. How about a pic of what you have?
Old Dec 7, 2016 | 11:37 AM
johnrem46's Avatar
johnrem46
no I just have an MSD box.. Can I remove the points add the pertronix and keep the MSD box
Old Dec 8, 2016 | 08:40 AM
69mach1377's Avatar
69mach1377
Not sure if they mix well, maybe you should use it with an MSD dizzy instead? It's a good box as Starfury said.
