67 Power steering issue, low RPM
Old 06-10-2017, 04:52 PM
67BrittanyFB
67BrittanyFB's Avatar
Default 67 Power steering issue, low RPM
Just put our 67 Fastback together after being apart for a couple years getting stripped, painted and now, rebuilt. Having an issue with the power steering completely failing at low RPMs, but is even a little sketchy in general RPM conditions. Thinking it is probably the pump, but perhaps the control valve. Advice on where to start and should I rebuild or just purchase rebuilt/new?
Thanks much!
67BrittanyFB is offline
Old 06-10-2017, 09:36 PM
Gun Jam
Moderator
Gun Jam's Avatar
what kind of fastback did you build? How do you plan to drive it?
Is it something that needs to stay original?
Gun Jam is offline
Old 06-11-2017, 11:23 PM
67BrittanyFB
Hi Gun Jam. It is a mostly stock Hi-PO 289, yes want to keep it as stock as it makes sense. I do drive it, so some upgrades as it make sense. Seems the Power Steering should be able to be left stock. It worked fine previously. I have had the care 35 years. Just having issues with the rebuild (and sitting for 2+ years).
