Back Up lights
Old Feb 12, 2018 | 08:24 AM
a29inst's Avatar
a29inst
Default Back Up lights
Have a 65 coupe 289 with Tremec 5 speed. Just replaced the under dash wire harness. Everything works as it should except my backup lights don't work when I go into reverse but come on when the under dash courtesy lights come on (open either door or select them by rotating headlight switch). Any thoughts or suggestions? Thanks.
Old Feb 12, 2018 | 12:50 PM
8 ball's Avatar
8 ball
Were the back-up lights an option in 65? I know they weren't standard so the harness you put on may not have them fed correctly. The lights should be fed through the back-up switch, top top fuse and through the ignition switch. Make sure the splice into the positive feed in your harness is before the fuse box. See attached snip. (the path is marked in orange)
princessnatalina
Aug 6, 2023 08:29 PM
Dom M
Oct 4, 2008 10:42 PM
phunnyguy
12
Aug 18, 2006 10:09 PM
