Alternator wiring
Old Apr 3, 2018 | 07:14 AM
Anzagi's Avatar
Anzagi
Default Alternator wiring
Good afternoon,
Am very new to the mustang world, having just bought a 66 289 v8 am now starting to create a plan and start working on it. Hopefully my questions are not too stupid!
I need replace the wiring harness from the alternator, and the wiring then seems to feed down into the main wiring loom at the front of the car. instead of connecting to the headlight to frame harness via connector, it seems to have been connected another way (see pics), shouldn't these two harnesses be connected via a nice clean connector?
Is it recommended I cut and add connectors here? or would it be worth my while replacing both harnesses whilst I am at it?
Am interested in your views please,
does that make sense??
Thanks for any help in advance, I am sure my questions will get less vague as time goes on!
Old Apr 3, 2018 | 01:06 PM
bop11's Avatar
bop11
This may help
Old Apr 3, 2018 | 02:51 PM
Anzagi's Avatar
Anzagi
That does yes thank you, so the default/typical set up would be with a connector block, asa pose to mine which looks like a repair/soldered together or something
So perhaps sensible to get the second harness new and replace so it is as should be?
Old Apr 4, 2018 | 09:27 AM
bop11's Avatar
bop11
We did the under hood new harness and it made things much easier and neater.
Old Apr 4, 2018 | 02:35 PM
Anzagi's Avatar
Anzagi
Thanks!
Evil_F
Jan 22, 2007 12:16 AM
cusoon4
May 16, 2005 03:15 PM
mysticsvtcobra96
Jan 12, 2005 06:27 PM
kevs66coupe
Oct 9, 2004 09:41 PM
