Running car with H-pipe
How will that cause the valves to burn? Are you talking about an H pipe without the mufflers installed? Not sure what you are asking here. But, even if you run the engine straight off the manifold it won't cause the valves to burn.
What your dad probably meant was that you could warp your valves. As long as you have some sort of pipes on the motor you are safe. However, if you run it without pipes (manifolds only) you could warp the valves.
ORIGINAL: 69FECoupe
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
