What wheel studs on 8.0 axle?
Old 10-31-2005, 09:20 AM
dirtbike123
dirtbike123's Avatar
Default What wheel studs on 8.0 axle?
Greetings from across the Pond!
I need to replace the wheel studs on a ford 8.0" axle, can any one confirm what they are and where I can get hold of some replacements, Ideally I'd like to get some longer than stock as I'm using disc's on the rear.
As I live in the UK I haven't been able to find anything suitable due to it's size and being imperial.
I measure them to be 5/8" spline and 1/2" (probably UNC) thread can anyone confirm this.
All help is appreciated
Laters
Nick
dirtbike123 is offline
Old 10-31-2005, 01:37 PM
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: What wheel studs on 8.0 axle?
Yep, they are 5/8 inches in diameter, but I question the 1/2 inch long thing. In your terms, they should be about 43mm long.
Soaring is offline
Old 11-01-2005, 10:19 AM
dirtbike123
Hi,
I decided to re-measured the holes in the mounting flange and the old studs that I already with a pair of calipers and came up with something unexpected, the holes measured damn near 0.600 (5/8" = 0.625) and the splined part of the studs came out at 0.615.
Presumably the 0.015 is for the spline to actually bite into the flange, Summit Racing list some of these press in studs that are 3.00 long and have a 1/2x20(UNF I think), is it plausable that they are actually 0.615 and not 0.625???
Sorry about the previous confusion "Soaring" the 1/2" part was the threaded part.
Regards
Nick
Old 11-01-2005, 03:22 PM
Soaring
I ♥ Acer
Soaring's Avatar
I'm not sure why you need the 3" bolts, since the standard is 2 1/2 inch. Do you really need the extra 1/2" just because of the disk upgrade?
Soaring is offline
Old 11-01-2005, 05:16 PM
dirtbike123
Hi
Probably should have made this clear at the time of the original post, the axle has been fitted to a 1972 Mk1 Escort(uk) and doesn't have a complete set of studs.
So I need to source a complete set, the car is also going to be raced and the regulation state that longer studs and sleeved lug nus are used so this kills two birds with one stone.
I'm just trying to avoid ordering the wrong type of studs as they're gonna be quite expensive by the time they've been shipped.
Laters
Nick
Old 11-01-2005, 05:31 PM
Soaring
I ♥ Acer
Soaring's Avatar
Oh, Ok. That explains it. You guys overseas must have a tremendous shipping cost.
Soaring is offline
JoshyGT
09-19-2017 08:52 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-01-2015 11:16 AM
firecoyote
09-27-2015 02:37 PM
09-10-2015 08:39 PM
Quick Reply: What wheel studs on 8.0 axle?
