1964 1/2 Mustang Horn Problem..ad ID of Unknown Horn Needed!
Old Dec 12, 2020 | 02:39 PM
pharbach's Avatar
pharbach
Default 1964 1/2 Mustang Horn Problem..ad ID of Unknown Horn Needed!
Hi There!
Recently bought a 64 1/2 Mustang and found the horns don't work. Steering control wiring to relay to horns are good. Horns physically were bad. I removed both covers and sprayed penetrant on internals, let sit overnight, then cleaned both horn actuating points with fine very
fine sandpaper, then cleaned everything up with contact cleaner. Was able to get the left horn working, after a bit of adjusting of the points, but the right horn only puts out a scratching sound from its diaphragm when actuated, so I know there is power going through the actuating
coil because of the scratching sound from the diaphragm. No matter how I adjust it and clean it, the horn does not want to sound off normally. I have done everything I know of to resurrect the horn to no avail. Any ideas to get this horn to work??
First photo is of the 64 1/2 horn with the cover off
Second & Third photo is of a vintage car horn that I am trying to identify! The horn works!! Does anyone know what car this horn came from ??
Attached Thumbnails 1964 1/2 Mustang Horn Problem..ad ID of Unknown Horn Needed!-64.5-right-horn.jpg   1964 1/2 Mustang Horn Problem..ad ID of Unknown Horn Needed!-unknownhorn01.jpg   1964 1/2 Mustang Horn Problem..ad ID of Unknown Horn Needed!-unknownhorn02.jpg
polus11
Mar 10, 2013 09:42 PM
grruminator78
Sep 5, 2006 06:48 PM
corvetteguy
Jul 25, 2006 04:22 PM
ToddW
Nov 4, 2004 04:29 AM
taco
Jul 30, 2004 07:47 PM
