Ignition wire mess
Old Aug 27, 2023 | 03:22 PM
Mostang66's Avatar
Mostang66
The old pink wire was the ballast resistor wire to the coil for reduced voltage in "Run". The points and condenser don't last very long on 12 volts. Where the old pink wire connected to the ignition switch is where you want to tie in the blue wire, I believe that is position #3 on your picture. It still would be good to verify that whatever you tie it in to, that it only has 12 volts when the key (ignition) is in the "Run" position.
Old Aug 27, 2023 | 03:41 PM
Frznrth123's Avatar
Frznrth123
I gave up on trying to figure out where the blue goes and just followed the diagram. A few changes here and there and it started / and better yet stayed running with the first crank.
Thanks for all the help.
Let’s hope for a nice fall.
Old Aug 27, 2023 | 03:47 PM
Mostang66's Avatar
Mostang66
There's no "Like" button on this forum.
(Liked) Mostang66
ronshorse
Aug 27, 2023 07:18 PM
6kyles7
Jun 7, 2010 06:29 PM
bobbyboura
Sep 14, 2007 06:46 AM
dastangman
Apr 23, 2007 10:40 AM
starman
May 13, 2006 03:55 PM
