transmission issues on a 65
Old Nov 30, 2023 | 08:04 AM
pap's Avatar
pap
Default transmission issues on a 65
Good morning I have a 1965 I think it has a c4 automatic transmission doesn't seem to shift through right I only feel it shift once possibly 1-2or 2-3 I don't think it's going into 1 at a stop any way I can adjust something to help thanks for any help
Old Nov 30, 2023 | 10:50 AM
Mostang66's Avatar
Mostang66
There's a zillion ways this could go. Before anything else, if you manually put the shifter in "1" does it seem to start out in 1st gear - and stay there? If it does, then a possibility could be that you have a working transmission from a slightly newer vehicle. To test that, put the shifter in the "2" position between "D" and "N". Do you now seem to have the full range of gears?
Old Nov 30, 2023 | 02:17 PM
pap's Avatar
pap
Default transmission issues in my 65
I will give it a try and let you know what happened thanks for your help
Will G
May 6, 2014 09:56 PM
68CSTANG
Feb 8, 2009 10:07 AM
GT5Oh89
Jul 30, 2007 09:03 PM
StockD15b
Mar 23, 2007 09:08 PM
buckythekangaroo
Nov 11, 2005 01:37 AM
