65 C4 no upshift 2-3
Old Aug 27, 2025 | 02:45 AM
ssg26k's Avatar
ssg26k
Default 65 C4 no upshift 2-3
I changed the shifter shaft seals and now no up shift from 2nd to 3rd gear. Removed valve body again after finding I misaligned the kickdown leaver to the valve body. I tried adjusting the shifter linkage as instructed in shop manual. I removed the kickdown linkage incase that was keeping it in 2nd gear. What did I do wrong? Car shifted fine before, it just had leaks. I also removed extension housing to replace output shaft bearing. This is my first time working on a Ford transmission.
teeeeg67
Dec 12, 2016 08:01 AM
mustangaod
May 8, 2012 08:06 PM
10ewolttam
Aug 22, 2010 04:28 PM
franko66
May 14, 2008 01:27 PM
creepshow
Apr 26, 2005 11:33 PM
