Can i trust these?
Old 11-08-2005, 08:01 PM
tylerdru
tylerdru's Avatar
Default Can i trust these?
can i trust these two 2 ton jack stands to hold my front end up?
[IMG]local://upfiles/20996/678CF0D155F7495B96537AB59C3573C8.jpg[/IMG]
tylerdru is offline
Old 11-08-2005, 08:27 PM
newownerof72
newownerof72's Avatar
Default RE: Can i trust these?
I jacked up a corner of my porch with some, I would but I don't know if anyone else would...I would worry more about them slipping and falling over then anything else,and that would be hard to do
newownerof72 is offline
Old 11-08-2005, 08:41 PM
2atey9
2atey9's Avatar
I have mine sitting on 4 of these at the moment, very sturdy. Should have no problem.
2atey9 is offline
Old 11-08-2005, 09:00 PM
351foxstang
351foxstang's Avatar
ive used them when replacing a clutch on my f250 with 7.3L diesel engine. your all set.
carl
351foxstang is offline
Old 11-08-2005, 10:54 PM
southernfordman
southernfordman's Avatar
I have actually seen one give on a honda civic, but I think it was a pro lift 1 ton. That looks good on your car and should have no probs.
southernfordman is offline
Old 11-08-2005, 11:34 PM
tylerdru
tylerdru's Avatar
1 ton is like 2,000 pounds right? OH well i was already under the car on my creeper. I got a kit with a 2 ton jack two 2ton stands and a creeper for $30 I am gonna buy two more stands so i can put the car up on four stands when i do disc brakes.
tylerdru is offline
Old 11-08-2005, 11:38 PM
6mustang6
6mustang6's Avatar
Yeah, think about it. A 65/66 mustang only wieghs in the area around 2500 lbs. As long as you have them in a good spot, you have nothing to worry about.
6mustang6 is offline
Old 11-08-2005, 11:55 PM
tylerdru
tylerdru's Avatar
I have them on the solid frame rails so i should be fine. Its just hard to trust two $10 stands to hold the car up, but now i think i trust them. And plus if something did happen (when no one is under the car) I could probably go after the makers of the jack considering i have pictures of the jacks being properly placed. Ok now i am just stretching it.
tylerdru is offline
Old 11-08-2005, 11:59 PM
6mustang6
6mustang6's Avatar
You mean stands?
Old 11-09-2005, 12:03 AM
pak133
pak133's Avatar
They'll hold the weight but you run into troble when the car is put into a position where it can shift. Please be very carefull. Always keep in mind that the car may shift from something as simple as turning a nut. Safety is no accident!!!
pak133 is offline
Quick Reply: Can i trust these?
