Harmonic Balancer Problem
Old Nov 13, 2005 | 12:38 PM
garywwelch's Avatar
garywwelch
Default Harmonic Balancer Problem
Morning Gang,
Yesterday I was doing some detailing and painting on the engine befoer I drop her into the car next weekend and desided to pull off the timing cover so I could install the new chrome dip stick tube. I got out my trusty 3 point puller and took off the Harmonic balancer. Much to my surprise it came off in 2 parts. A round metal ring around the a smaller ring with some type of rubber between them. After I got the smaller one off I I tried to put it back together. It appears they will have to be pressed on. The rubber ring is very brittle so I thought I would replace the harmonic balancer with a new one. So here is the question. I have seen sever after market types, fluid, stock etc. What do you guys recommended? Do you have a certain brand you like best. ALso I have noticed two different weights i.e 28 , 28.4, 50 oz both are offering a 3 and 4 bolt styles. What is the right one. I am building a 302 for my 66.
I am not concerned in being Ford original on this engine. I have the original 289 that I will build out later to meet that statndard.
Bring on the suggestions.
Thanks for your help,
Gary
Old Nov 13, 2005 | 12:48 PM
6mustang6's Avatar
6mustang6
Default RE: Harmonic Balancer Problem
The little metal sleeve and rubber stuff, is something you can buy and put back on it. They are for to keep it from leaking oil. I got mine from Advance Auto Parts for $12. Just replace that again. It's a metal sleeve, and some gooey stuff, that holds on the metal sleeve. I didn't put on the goo, when i did mine, and i think it came off and damaged my seal, Anyhow, it's leaking oil from it.[:@]
Old Nov 13, 2005 | 12:59 PM
69mach1377's Avatar
69mach1377
I don't think he is talking about the repair sleeve.
I like my StreetDamper, but that is overkill for a stocker.
Old Nov 13, 2005 | 02:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
The 50 oz. is for like 1984-95 models of 302 5.0L. The 28 should be your choice. Never heard of a 24.4.
mtgldr
Feb 3, 2024 09:00 PM
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
