backup lights question
Old Nov 15, 2005 | 12:54 PM
cthornton's Avatar
cthornton
Default backup lights question
Installed new backup lights on 1965 mustang automatic. The new lights do not come on when the gear shift is in reverse position; only when it's in a certain spot somewhere between reverse and neutral. Any suggestions on a fix? Parts store suggested trying a new neutral safety switch. Think that's the problem?
Old Nov 15, 2005 | 01:25 PM
TBIAgent69's Avatar
TBIAgent69
Default RE: backup lights question
My guess is that if it was a bad reverse sensing switch, it'd not work at all, but that's just an educated guess. You may have some slop in the shifter linkage, or it may be out of adjustment causing the problem. Do you have problems starting it as well sometimes and need to play with the shifter to get it to work?
Old Nov 15, 2005 | 01:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
You may also have to adjust the position of the back-up light switch on the tranny shifter. Something sounds like you have some slop in the shifter, but the neutral safety switch is probably not the culprit.
Old Nov 16, 2005 | 05:01 PM
cthornton's Avatar
cthornton
Yes I do have to knock the shifter back towards me to get it to start. So it sounds like I might be able to adjust the neutral safety switch to fix the problem. Thanks for the help.
Nurdyguy
Jan 20, 2025 04:38 PM
Nick Oliver
Oct 17, 2018 04:22 AM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
