69 with 429
Old Nov 18, 2005 | 01:14 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default 69 with 429
my brother is working on a 69 mercury cougar and has found a 429 4v engine in the junkyard out of a marquis vert will this engine fit with out cutting the shock towers?
Old Nov 18, 2005 | 02:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 69 with 429
Let' assume the Cougar engine bay is the same as a 69 Mustang. If so, then it will fit witwhout taking out the shock towers. Take a look at this Boss 429 in a 69 Mustang. You will notice, however there is one hellava suspension under it to support that monster. This is a factory 1969 Mustang Boss 429.
Old Nov 19, 2005 | 10:29 AM
THUMPIN455's Avatar
THUMPIN455
Um yep a 429/460 will fit in the 69/70 Cougar. The Cougar was essentially the same car underneath the skin as the Mustang. Cougars have a longer wheelbase for a smoother ride, but all the parts like suspension, engine, and drivetrain will interchange. Driveshafts are a bit different tho. Also Cougars had disc brakes and V8's 67-70. If you find one that doesnt, it was the victim of a downgrade swap, usually to replace parts on a Mustang, then reassembled with the old parts.
A 429/460 will fit in the 67/68 with some work, but its a no brainer in the 69/70. I prefer FE's, especially since Edelbrock makes heads for them now. One of my USAF buds has a 68 428 Cougar XR7 GT. Now that is one sweet ride...
Old Nov 19, 2005 | 10:54 AM
69FECoupe's Avatar
69FECoupe
As I mentioned a few days ago on this subject, Boss9 cars were NOT factory assembled machines. They were built by a company named Kar-Kraft who DID modify the shock towers to make the engine fit. That said, a standard 429/460 should fit in a 69 engine bay without modifications. The front sway bar and springs in the Boss car are special but the rest of the front end is pretty much run of the mill FE Mustang stuff.
RSRXION
May 10, 2006 02:07 AM
RSRXION
Jan 24, 2006 12:10 PM
73Cleveland
Nov 19, 2005 07:34 PM
JoeyD
Nov 10, 2005 11:38 AM
