disc brake swap
Old Dec 5, 2005 | 03:40 PM
gconnsr's Avatar
gconnsr
Default disc brake swap
Will a disc brake setup from a 72 Mustang fit a 67? Also, will the rear end swap or is there a diff.?
Old Dec 5, 2005 | 04:14 PM
gta289's Avatar
gta289
Default RE: disc brake swap
theres a difference in sizes, some had 8 inch 8.8 and 9 inch differentals
Old Dec 5, 2005 | 05:03 PM
waxyourboard's Avatar
waxyourboard
About the rear end... the '67 mustang has a 59.25" wide rear end... the '72 has a 61.25" rear end. So it's about 2 inches wider (1" on each side)
If your wheels arent that wide, or have the right backspacing, it wouldn't be a problem, although the spring perches might be off by a little bit
Also are you switching gear diameters? (7.25-8-9) Because you might have to have your driveshaft shortened (or lengthened... if you're going from 7.25 to an 8)
http://www.dfwmotorsport.com/fairlane/9inchrearends.htm
Old Dec 6, 2005 | 01:05 AM
gconnsr's Avatar
gconnsr
Thanks for the help. Now I'm thinking about restoring and selling the 72, then I would have more money to put my other cars together. My mind twists way to fast!
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
maestro1024
Sep 21, 2015 02:40 PM
uberstang1
Sep 21, 2015 09:04 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
