troubles... again
Old Dec 13, 2005 | 02:10 PM
66ckurt's Avatar
66ckurt
Default troubles... again
alright im calling for the help of all the guys with the experience of the inderds of a 66. I got a problem ,well i think its 2 problems myself, the story starts off with me getting a new alt because the bearing was gone in the original and a few days later it starts to act up funny sound coming from under the hood and the amp meter in the car was charging off the chart so i took it as a falty alternator. I took it back and got a better quality on in its place tossed in a new airfilter and was set only now its acting up again. Im just gunna list out everything its doign in hopes someone has run into this problem before and help or someone whos just that good with mustangs can help me out. 1 The amp meter is now pointing to the D ( before it was all the way to the C) 2 head lights are very dim 3 turn signals bearly work if at all, they go on and off when they feel like it, 4 my cd deck turns off and on ramdomly and 5 its stalling at lights now i kinda think this is a seperate problem cuz i can't think of nething that stalling would havin in common with everything else.
Old Dec 13, 2005 | 02:21 PM
Gregs68's Avatar
Gregs68
Default RE: troubles... again
how is your battery? is the alt hooked up properly?
Old Dec 13, 2005 | 02:53 PM
66ckurt's Avatar
66ckurt
ya everything is hooked up it all is still working sorta when i give it a little gas the amp meter will go up and my lights will go brighter
Old Dec 13, 2005 | 05:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Did you also replace the voltage regulator when you replaced the alternator? If not, that's your next purchase. Also, double check the connections from the battery to the starter relay and the ground. Make sure they are clean.
Old Dec 13, 2005 | 08:07 PM
garywwelch's Avatar
garywwelch
From what I have been told about these cars is when you replace the alt you shoudl go ahead and do the regulator as well. Since it is external and is in line with the alt, ggod chance it is bad. Certainly sounds like it based on your discription.
Good Luck and keep us posted
Gary
Old Dec 13, 2005 | 09:19 PM
66ckurt's Avatar
66ckurt
ah i thought the regulator was in the alternator its self thats a help ful hint and ya i do really need to do a good once over of the wires for some reason when i bought it the positive wire to the battery was black and the negative was red :P, i also bought a new light switch to see if thats a problem with the lights and because i got no dash lights ne tricks to getting the old until out not as easy as it seemed when i took the part outa the box.
Old Dec 13, 2005 | 11:49 PM
Nick's Avatar
Nick
Mine stalls all the time @ lights, sometimes if I let my foot off of the gas in traffic. I posted on the "Found on Road Dead" thread. I had about 16,500 miles on mine when it started. I have 18,000 now.
I do not have any of the electrical problems you have.
Good luck.
Old Dec 13, 2005 | 11:57 PM
66ckurt's Avatar
66ckurt
you ever find a reason for stalling
Bowtietraitor
Dec 16, 2010 08:56 PM
Looker
Jul 21, 2008 02:14 PM
DrmZero
Jan 9, 2008 05:21 PM
mattdel
Jul 30, 2007 06:53 PM
